|  Sierra 1.6 GL P reg CAn someone answer the following questions. I have managed to track down a 1.6 ford sierra GL P reg. Does anybody know if that would be okay for the Roadster, I assume it will but will it give enough power for track days.? Does it come with EFI? Thank you |
|   GL? They stoped that trim in 89 P reg? The last know cars are on an M plate. 1.6 Could be Pinto Carbed CVH Carbed CVH CFi ( single point carb ) TT |
|   Ps.. track days are not all about power, a 1600 is not exactly blessed in the HP department but should still be fun. TT |
|   I am going to look at the car in the new year, might be a GLS. If all goes to plan I should get it for near to nothing and still has the keys and paperwork. Is it worth holding out for the 2.0 Thank you Happyjo |
|   GLS was only 2.0 and 2.9 GLX was a 1.6 trim from 91-93 TT Last edited by twinturbo : 28th December 2009 at 01:25 PM. |
|   1.6 will be fine to start with.  most people rip the pintos out after they are through iva. |
|   Thanks guys, I am thinking about fuel economy/ insurance etc. Another assumption, if i fit the 1.6 then it has the same gearbox and engine mounts so transplanting the bigger enegine should be quite easy later. |
|   the 1.6 will be a pinto and it's type 9 box will fit most other 4pot fords althought the 1.6 is not as strong as the 2.0 BOX. How many miles do you expect to do a year? MPG is uualy not worth thinking about unless you plan to do a lot of touring. TT
				__________________ You only get a woosh with a dump valve Build Thread Man Cave Mantiques Cecil Street Auto Repairs Garage Carlisle Build Cost £4181.65 - Last - Wheel Cylinders |
|   I know this sounds a bit far off, i have not even bought the steel yet. But I would love to drive down to the south of france on a touring holiday just before i retire. another 12 years to go so should just have enough time to build then. The london to brighton sounds great to. Cheers for your reply Happyjo  |
| Thread Tools | |
| Display Modes | |
