Good Evening all,
Nearly to the point of having a rolling chassis I'm looking at the headlight mounting brackets (the oval tubing) and I am thinking can I just use some 25mm round tube instead of the oval tube.What are your thoughts? Regards Jon |
Oval tube is purely an aesthetic issue. Round tube will perform the same job and in my experience, much easier to get hold of.
I crushed some 19mm round tube in the vice, and after several practices it seemed pretty good.
I've tried to post pictures but as usual no joy. |
Seriously though, round tube will be fine or has been sugested, if you have a vice that is up to the job you can soon make it oval I made a small oval dolly & ovalised some 25mm round tube on the anvil block ![]()
I am not a complete idiot...........Some of the parts are missing !! Ronnie ![]() www.roadster-builders.co.uk |
Many thanks for that guys, will use some round section instead.
Regards Jon |
| Thread Tools | |
| Display Modes | |
