Old 1st March 2010, 09:53 PM
steve8274 steve8274 is offline
Default what paint do i use
hi
i am getting ready for rebuilding engine and would like to paint engine and gearbox.
what is the best paint to use and do you need primer/rust treatment first. (i have removed rust wat i can see)
is the paint expensiveand how much is required to do both engine and gearbox
thanks
Old 1st March 2010, 10:23 PM
Jimmyd Jimmyd is offline
A bit of degreasing, wire brush and paint with Hammerite is as good a job as any. Use the smooth finish. Done this a few times long lasting tough finish.
J
Old 1st March 2010, 10:49 PM
i did my block and head with spray can hamerite. gives a much better finish but you have to make sure that you cover up every little nook and cranny.
Old 1st March 2010, 10:58 PM
took the best part of 3days to get it like that. the only way to get a really nice clean engine is to fully strip degrease, de-rust, degrease again, wash off in solvent bath, then paint.
Old 4th March 2010, 12:45 PM
wont the hammerite come off with heat. thought i read on can it only goes to 60 degrees?
how long will it last
thanks
Old 4th March 2010, 01:03 PM
Engine Enamle
Old 4th March 2010, 01:25 PM
davidimurray's Avatar
I used the POR engine paint - expensive but seems great so far.
Old 4th March 2010, 01:43 PM
well my engine has been run up to heat more than a few times and there are no signs of it coming off. have painted other engines in previous cars and it always seemed to last
Old 4th March 2010, 06:08 PM
Davey's Avatar
Davey Davey is offline
Hammerite is good for 300 C before it starts to blister. I once painted a steam engine boiler with it and that regularly went up to 150-175C with no discolouration or other problems, I also used Hammerite primer on that job.
D.
Old 5th April 2010, 10:42 AM
old_bill old_bill is offline
Ash
Is it also OK to use on the brake calipers and Diff without too much preparation?
Bill
http://www.flickr.com/photos/old_bill/
