Old 13th April 2010, 08:07 PM
steve8274 steve8274 is offline
Default diff seals and oil
hi
just cleaning all my parts up and decided to change seals at side of diff (of sierra)
do the seals just prise out and new ones slide in or is there anything else i should do. does look straight forward but just want to check first.
also does anyone know what oil is used in diff. drained mine of, then checked haynes manual and it doesnt say what to put back in! oops
any advice appreciated
steve
Old 13th April 2010, 08:52 PM
SAE90 Hypoid acording to my data.
Old 13th April 2010, 09:29 PM
Yes Steve,
I replaced the front seal on mine, if you prize out the old ones out with a screwdriver, clean out the housing and gently tap in the new ones with a piece of wood that just fits in snug.
Standard diff and gearbox oil is fine for the diff.
AndyH
Old 13th April 2010, 10:15 PM
thanks for confirming my thoughts. just thought id check. expensive to replace if damaged.
thanks for oil spec too
Old 15th April 2010, 06:02 PM
the seals dont seem to want to come out. i have even drilled through it and put screw in to try and pull out. there just not budging!
is there definately not something else that needs to be done first
thanks
Old 15th April 2010, 06:20 PM
The drive shaft seals have no trick fixings.
I usually use a very large (MF) flat bladed screwdriver to prise em out
If they are being a royal pain in the ass, try finding a peice of slim flat bar, put a small 90 degree bend in one end & a larger 90 degree bend on the other end.
Hook one end under the seal & smartly tap the other end in an upward motion with a small hammer .... That should get it moving
Old 15th April 2010, 07:07 PM
Right .... Just been out & removed my diff seals !!
They were on my to do list & the diff was sitting in the middle of the floor anyways.
No trick fixings but boy, were they tight
Took a serious bit of mullering to get them out .... My trusty MF screw driver would not shift them.
My tyre lever would not shift them at first .... I took a large pin punch & smartly tapped the flat face of the seal, in an inwards motion towards where the centre of the shaft would be.
This helped to release the bond at the sides of the seal .... You'll need to do it in a few places, working your way around the seal.
Placed my lever under the face of the seal, a couple of sharp taps later & out they popped
No I haven't got a set of seal pullers, nor do I intend to buy some just for a one off job
Anyways, jobs a good'un & no dammage done
Old 15th April 2010, 08:50 PM
thanks
will give that a try. fingers crossed
