Old 8th July 2010, 01:33 PM
davidimurray's Avatar
Default Battery Location
Am I missing a trick here? I notice most people mount theres up on the scuttle, but what about the area in front of the passenger footwell but behind the engine mount? Seems like an ideal area and would get a nice heavy bit low down.
Anyone done this?
Old 8th July 2010, 02:00 PM
Hi David,
I suppose it depends on which engine you have, as I,m just finishing off my exhaust down pipe ( CVH engine ) & my down pipe exits precisely where you are suggesting to put the battery,
My battery is up on the scuttle as I have the GRP bulkhead from Saturn & it has a purpose made recess for the battery ( with a little cutting to allow battery to sit flush ), this also made me think to put all my "Checkable " components along the same scuttle area.......
battery, relay bank, fuse boxes, expansion bottle, oil catch tank & the ignition module are all along the scuttle bulkhead.
Old 8th July 2010, 02:05 PM
So there may be an advantage to having a Pinto
I suspect the battery would end up below my carbs so could make swapping it at a later date difficult - but how often do you change the battery!? Are you using the standard sierra battery or have you gone for something smaller?
Old 8th July 2010, 02:13 PM
well a pinto also makes a good anchor sorry couldn,t resist.
i,m not sure if Mr IVA man would be happy with the battery sitting under the carb/s.......fuel + battery hmmmmm......not a pleasant thought ( just my humble opinion tho)
Well you know how tight my budget is...........so i,ve used the battery that came with my donor, it looked fairly new so thought I,d do my bit & recycle it
Old 8th July 2010, 02:32 PM
Enoch Enoch is offline
It's fine to mount it there if the exhaust comes out the driver's side. Lots of us have the exhaust coming out to the left so it's best to mount the battery "up top" away from the heat.
Old 8th July 2010, 06:46 PM
Hmmm - sounds like it might be a plan
What sort of battery size is everyone using - the original that came out of my sierra was whopping!
Old 12th July 2010, 09:10 PM
Eternal Eternal is offline
hah you should see the one out of my Stagea its like a truck battery!
Skyline Roadster
Old 13th July 2010, 08:30 AM
Coozer's Avatar
Coozer Coozer is offline
I have my red top 25 inside the passenger footwell.
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 13th July 2010, 08:38 AM
Coozer
Am I right in thinking that you're running a Duratec? Does the red top crank it over ok?
Old 13th July 2010, 10:09 AM
Coozer's Avatar
Its a ST170 and that battery got through the 1 1/2 year build stage and now 2 years on the road without any charging.
It turns it over no problem whatsoever. Plus it can be mounted flat as well.
LG,
