Old 10th August 2010, 02:40 PM
tkpm tkpm is offline
Default Track Rod Issue
I seem to have a problem with the track rod ends,
The hole in the sierra uprights is 14mm at the wide end but the rs2000 track rod is only 12mm at the base.
Could someone please check there track rods and uprights measurements for me thanks.
Terry
Old 10th August 2010, 06:31 PM
It's tapered so the TRE should go in and stop.
Old 10th August 2010, 06:32 PM
why RS2K TRE by the way is should be a sierra one to match the sierra hub.
Old 10th August 2010, 07:34 PM
I if memory serves me right, the book say's to use them.
Terry
Old 10th August 2010, 07:38 PM
james3004's Avatar
The book says use sierra ones?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 10th August 2010, 07:58 PM
The rs2000 ones are from rally design, which is also the reason for the problem with the length of the extensions.
They will fit they are tapered, if you push the rubber down a bit you will see it gets wider.
Old 10th August 2010, 11:02 PM
Thanks for the help guys, i new i couldn't trust my memory, doh
SeriesLandy, if i push the rubber all the way down, it's still a bad fit.
I bought one of these kits from EDS-Motorsport,
http://cgi.ebay.co.uk/Front-Hub-Join...item5adb4128a0
Will order the Sierra ones tomorrow
Once again thanks for the help and advice.
Terry
