Old 11th August 2010, 03:33 PM
old_bill old_bill is offline
Default brake master cylinder
My donor had ABS so I will need a new master cylinder. I'm assuming here that a mc from any suitable car will do, not just the sierra one. Any thoughts or guidance appreciated.
Bill
http://www.flickr.com/photos/old_bill/
Old 11th August 2010, 03:53 PM
davidimurray's Avatar
You will need to ensure that the diameter of the pistons for the front and rear circuits are the same diameter - have a searhc for brakes international on google as they have a great online catalogue.
Old 22nd August 2010, 05:13 PM
Thanks David I had a quick look and it appears that the MC from a Fiat 124 will do the job at around £16.
Also checked Locost forum and found that some builders were using this.
Bill
Old 24th August 2010, 07:41 PM
james3004's Avatar
is that for discs or drums on the rear?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 25th August 2010, 09:08 AM
I've got discs all round. I may have to put a reducer in the braking system.
The brake pads on the rear are smaller than the front so I don't know yet if this will make a difference.
Also I've found out that it's quite expensive to buy the fluid reservoir which will have to be adapted to suit the MC (around £37 incl Vat from CBS).
I'm keeping my options open and head on down to the breakers at the weekend to see if I can find a suitable cylinder and reservoir complete.
I do have a second hand sierra cylinder which requires new seals, however the reservoir sits at an angle when mounted and I am concerned that this will affect the level warning.
Bill
Old 25th August 2010, 12:11 PM
My reservoir also sits at an angle from the donor sierra but the fluid warning still works fine
