Old 4th September 2010, 08:42 PM
davidimurray's Avatar
Default Aerocatches
Has anyone used any of these with a saturn bonnet? If so have you used the flush fit or exterior mounted ones?
Old 4th September 2010, 09:13 PM
Deanno's Avatar
Deanno Deanno is offline
I was planning on using the locking ones but not sure about IVA?
Old 5th September 2010, 04:49 PM
According to IVA, if the projection sticks out less than 5mm then the edges need to be blunted. According to the aerocatch drawing - http://www.aerocatch.com/updoc/Tech_...flush_dims.pdf if you use the ones that mount externally then they only stick out 2.5mm so should be ok.
The flush mount ones need a bonding plate so the bonnet would need to be less than 2.5mm thick.
Old 6th September 2010, 09:00 PM
james3004's Avatar
I pesonally think the top mounted ones would look better, but I think you need 2 sets to secure the bonnet properly?
I have been looking for an alternitive the the rubber things, they look awful
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 6th September 2010, 09:58 PM
I bought a set of the flush but havnt fitted them yet. Bro in law bought a set of plus flush for his mini boot but they don't look as good ( he's not as precise as me)
The Westfield kit uses a pin to locate the front so you only need a pair.
