Old 9th September 2010, 07:33 PM
Deanno's Avatar
Deanno Deanno is offline
Default Behind seat pannel cut out
can anyone help?
I'm doing the templates for the car and am about to start drawing but then noticed there is no hight for the cut out, it gives the width but no height
Old 9th September 2010, 08:11 PM
David_17's Avatar
David_17 David_17 is offline
Tape measure? Ruler?
*updated 7/6/11*
Old 9th September 2010, 08:14 PM
Deanno's Avatar
I would but have not made the car yet I was just intending to do the templates ready.
Old 9th September 2010, 08:32 PM
the plan for the template of the seat back panel is on page 97, top sketch, overall height is 570mm, but be aware of the two bend lines, tho the sketch does show the position/dimensions of the required bend lines to facilitate the 17degree lean back of the seat back area.
Hope this helps.
Old 9th September 2010, 08:40 PM
Deanno's Avatar
HI Andy, that is all drawn the bit i'm after is the cut out for the tunnel (I could'nt think of the name earlier) i've got the width but not the height.
Old 9th September 2010, 08:50 PM
My apologies,
The height of the tranny tunnel side panel, if thats what you need is 302mm at the rear ( thats fitted upto the seat back panel end) & the gear stick end is 345mm on drivers side & 352mm on passenger side.................
OR
If you look at the diagram on page 45 , lower sketch it shows the height from the base of the bottom chassis rail to the top of the tranny tunnel rail TT7 as 305mm perpendicular height.
hope this helps
Old 9th September 2010, 09:04 PM
Deanno's Avatar
Cheers Andy
