Old 19th September 2010, 02:25 PM
mikemph mikemph is offline
Default Complete list of materials needed!!
Hi
This is my first post
The plan 2 zetec, i have mt75 gearbox already from a friend building mk indy 1200 BEC. I am going to try and do everything possible to do it on a very low budget. I an very well honed at megasquirt now and have experince setting up on the rollers so running the zetec on throttle bodies from a bike is where i am heading.
I am looking for a list of exactly how much of each size box/tube i need for complete chassis including suspension.
I work in an engineering workshop where i have access to just about an saw/welder lathe/milling machine/cnc plasma etc i will need to build. I will do my best to order everything through work which I can then order at cost+10%. Hope to get the material as cheap as possible.
So far this looks to be a friendly forum
Old 19th September 2010, 03:30 PM
http://www.haynes.co.uk/forums/showt...t=cutting+list
Old 19th September 2010, 06:43 PM
Twin's Avatar
Twin Twin is offline
Welcome to the mad house
Twin
CSF £857.19
Twins Roadster
Old 19th September 2010, 08:10 PM
Thanks for the welcome.
Thanks for the link... all i can see is the list for the box section.
What other tube will I need?
Maybe I should get my head stuck into the book and work it out for myself
Old 19th September 2010, 10:52 PM
Hi Mike
6m of 25mm Dia (1") seamless mechanical grade 2mm wall and 3m of 19mmDia (3/4") seamless mech grade 2mm wall for the suspension.... a lump of 3mm steel i'd guess around 1/2 sq m for chassis plates .... a small chunk of 5mm steel around 1/2 sq m of 1mm steel. Check the book for the rest as I am not that far on my build yet, if your in an engineering shop I guess the scrap bin will furnish you with all you will need.......oh.... welcome and get building.
rgds
Kev
