Old 26th September 2010, 10:43 PM
David_17's Avatar
David_17 David_17 is offline
Default Heat proof edge trim
As title, does it exist?
I need something to go round the seem on my cataylic converter and round the end of my tail pipe.
I don't really want a big cover over the whole exhaust, as it's just something else to remove after iva
*updated 7/6/11*
Old 27th September 2010, 04:56 AM
Would the catalytic converter not fit in the engine bay,just a thought
I think its likely you would have to make a small heatshield to go around it to get through iva as it is at the moment.or just wrap it with exhaust heat tape.
Old 27th September 2010, 07:07 AM
David_17's Avatar
My original plan was for it to go in the engine bay, but theres not enoug room
Hmmm... Could wrap the full lot with this stuff.
http://cgi.ebay.co.uk/51mm-2-Exhaust...item4cf1b9622c
That would protect from heat and cover the sharp edges.
What do you think?
*updated 7/6/11*
Old 27th September 2010, 09:45 AM
I would go with a perforated shield, I am not sure what effect wrapping a cat would have as the heat build up may be detramental.
You will also need so sort of heat blanket next to the side pannel to avoid scorching that.
