Old 12th October 2010, 09:30 PM
Default D1 And D2
Hi
Can someone please help me, I have started to fit the diagonals to my chassis. However D1 and D2 dont look right. I know they will not line up perfectly with the uprights and top/bottom rails but I do not want any issues when fitting side panels.
Do I need to inset D1/2 so the allloy panel will fit flush between the upper/lower rails. Or do I line up the outside edge of D1/2 with the rails, if so, will the panel be shaped aroung the material that protrudes as a result of this?
Hope this makes sense to somebody
Old 12th October 2010, 10:11 PM
Middled mine if that helps.
If using an alloy side panel there is a fold there & should not foul those two diagonals.
I believe the Saturn side panel will not foul those either
Pesonally I doubt it will make too much difference if you middle them or set them to the outer edge. ( I middled them because it just looked to be the right thing to do )
Old 12th October 2010, 11:08 PM
Thanks Bonzo, yeah I think middling them would be the way to go. Still get strength but looks a lot neater.
Cheers, thats what I will do
Leigh
Old 13th October 2010, 08:50 AM
Spot on there Ronnie , the GRP side panels don,t come into contact with these diagonals.
Old 10th November 2010, 09:41 AM
Twin's Avatar
Twin Twin is offline
I found it easyer to fit after I had cut them out of 19x19 & not 25x25
Twin
CSF £857.19
Twins Roadster
Old 10th November 2010, 08:22 PM
Hi mate dont make the mistake I made, got so carried away cutting up my diagonals, that I cut them out of 25mm not 19mm, bet your gonna double check what you have cut them out of ha ha
