Old 28th November 2010, 06:03 PM
Default wishbone bracket jig?
does anyone have a set of the wishbone bracket jigs for sale / rent ?
or are there any hints tips people can share?
im nearly at the point where im going to need them
rob
Old 28th November 2010, 06:20 PM
I can,t believe how quick your build has progressed nice one Rob .
I know of a forum member that might still have the wooden jig, I know he,s finished making his wishbones, I,ll ask him if he is looking to move it on to another builder. Unless he see,s this thread first
Any more pics of the chassis????
Old 28th November 2010, 07:26 PM
Cheers andy im doing things a little higgldy piggldy hoping to make the rear uprights from saturns kit this week and get the wishbones on rear diff mounted the goal is still rolling chassis with drive train an engine fitted by christmas ill get some more pics up later in the week lost the welder this weekend otherwise uprights would already be done
Old 28th November 2010, 07:29 PM
Just to confirm its the jig to mount the u shaped brackets to the chassis im after
wishbones courtesy of saturn are sat waiting for home positions
Old 28th November 2010, 07:42 PM
Doh, silly me
I don,t know why but I thought you meant the jig for "making" the wishbones, I,ll go back to sleep
I,m sure you,ll achieve your target by christmas, can,t wait to see the engine & drive train in your chassis .
Old 28th November 2010, 07:48 PM
gingea1pom's Avatar
I didn’t use a jig!
I used some M12 threaded bar and spaced two wishbone mounts at the correct distance along the bar,
Then measured many many times
Then tacked then measured again
Then tried a wishbone in to check.
Worked for me just took my time.
Cheers Ginge
Build Pictures
Old 28th November 2010, 07:52 PM
I have considered a similar route ginge but if i can get some jigs by the weekend it should be easier ive already messed about with the wishbones so id like the brackets in optimum position as im not sure how the modified wishbones will behave yet :-)
