Old 9th December 2010, 10:27 PM
davidimurray's Avatar
Default Clutch pedal Bending
Has anyone else noticed that the clutch pedal is rather weak?
I popped the engine in a couple of evenings ago, hooked the clutch cable and lent into the tub to actuate the pedal. As I pushed the pedal (slightly offset load) forward it promptly bent sideways! I seem to remember another member (Dogwood??) having this problem on his car at a set of traffic lights.
I plan on adding gussets to either side of the pedal of the pedal to strengthen it up.
Anyone else encountered this problem?
Old 9th December 2010, 10:31 PM
Tilly819 Tilly819 is offline
yep same problem, just make it out of thicker plate or add a brace to it
tilly
Old 9th December 2010, 10:54 PM
Yep, me too, haven't addressed it yet!
Old 9th December 2010, 11:15 PM
Glad it's not just me - perhaps some of the manufacturers on here should include extra braces as part of their kits?
Old 10th December 2010, 06:40 AM
adrian h was the one that ben his pedal while trying to race another car off the lights lol. 5mm plate is a much better solution to the problem
Old 10th December 2010, 07:58 AM
Same here, promptly changed to 6mm after the first drive out!
Old 10th December 2010, 05:52 PM
dogwood's Avatar
dogwood dogwood is offline
Nope weren't me.
I made mine out out of 5mm as well
I did change to hanging peddles as I found the Roadster ones a bit short for my plates of meat
David.
Old 11th December 2010, 10:27 AM
I think I saw Handy or spud say that Saturn also use 5mm plate for the clutch pedal. I had some 4 mm strip lying around so I tried that.
Old 11th December 2010, 12:41 PM
Same happened to mine, 3mm just isn't enough so they are all cut out of 5mm now.
Cheers...AndyH
