Old 18th January 2011, 09:39 PM
shaun shaun is offline
Default 2.0 Zetec sump mods.
Hi all,
About to start mods on my sump, 2.0 Zetec. What would the best thickness ali be to do these mods? I was thinking 3mm or 5mm. Am I correct?
http://www.shaunsroadster.wordpress.com
YOU CAN NEVER HAVE TOO MANY TOOLS!!!!
Old 18th January 2011, 10:36 PM
Use the same thickness as the sump is made from originally.I would think 3mm would be enough.
If you are worried about it getting hit during use you could make a bash plate to cover it.
Old 19th January 2011, 08:28 AM
When I modified my aluminium sump, I cut a band out of it, and welded the bottom (complete with drain plug) back on. Didn't have to by any additional aluminium.
But to answer your question, while a sump is around 2-3mm thick, its also covered in reinforcing ribs. If your going to throw sheet of aluminium to make a flat bottom, I'd use 5mm.
Old 19th January 2011, 11:14 AM
Thanks for that, i was going to cut a band out but the guy who had the engine before me tried to modify it and basically wrecked the bottom, so I have to make a new bottom , 5mm it is then!!
Old 19th January 2011, 11:56 AM
any idea what amount needs to be removed (fiesta,escort sums are diffrent to mondeo)
my box is still in the sierra so it would be good to have the block bottom to sump bottom distence if any one has it
Old 19th January 2011, 06:22 PM
Get yourself one of these Shaun,
http://www.dunnellengines.com/zetec_...artno=RMP1400C
Waiting for mine to arrive. Was fed up with oil surges and foaming of the oil especially on the track. Bit pricey but a lovely bit of kit, got to treat yourself now and again.
Andrew.....
Old 20th January 2011, 12:57 AM
Here's the sump from the 1993 Mondeo 2.0, with the 15 cm waterline marked out:
http://picasaweb.google.com/10088104...eat=directlink
For the Type 9 box, the distance from the centre of the input shaft to the bottom of the bell is about 155 mm.
Old 26th January 2011, 05:55 PM
yes fiesta has the bulge at no1 cyl end
Old 26th January 2011, 05:56 PM
chears for that
Old 26th January 2011, 06:48 PM
Wink
Here's the mod I done to my 1.8 Silvertop Baz
Cut line marked out
Material removed
Job done
I worked out that I had lost aproximately 1/2 litre of oil capacity .... If needed, I could extend the rear of the pan, I'll see what the engine has to say first
