Old 21st January 2011, 05:52 PM
Andy_B Andy_B is offline
Default Petrol tank finished
First attempt at Ali welding so be gentle...pressure tested to 5bar only one leak (arrow) now re welded.. Sump made from 5" pipe ...filler from a section of zip up scaffolding (now a bit wobbly) !!
http://i1229.photobucket.com/albums/...t/P1210100.jpg
http://i1229.photobucket.com/albums/...t/P1210101.jpg
http://i1229.photobucket.com/albums/...t/P1210102.jpg
Even think i have learned between direct link and hyper link pics !!
Old 21st January 2011, 05:58 PM
well done
did you tig it?
Old 21st January 2011, 05:59 PM
Yes Tig welded wish i had used the current setting i used to fix the leak ...i cranked it up a bit and had to go like the clappers...but much neater..
Old 21st January 2011, 08:02 PM
5 bar or did you mean psi?
You can be confident about your first attempt at ali if it can hold 5 bar
Old 21st January 2011, 09:17 PM
it did kinda balloon at the sides a wee bit but better safe than sorry !!!
Old 21st January 2011, 11:06 PM
i would check you baffle in the middle. i did that on mine and cracked the welds first time round
