Old 27th January 2011, 08:44 AM
Default Steel CVH Sump to good home
Recently taken off a modified steel sump from a 1.8cvh which was upgraded to a new ali one. Sump is free to a good home, P&P £15, if anybody genuinely needs one.
The sump includes pick up pipe but will need a new gasket, will not be upto track or hard driving but will be fine for general use or just to get a cvh car through IVA prior to upgrading.
Let me Know....Andrew
Old 27th January 2011, 09:52 AM
WoW
Thats a great help to a forum member needing one of these, especially as its already been shortened & ready for installing into the Roadster chassis, they are becoming hard to find .......& expensive when you do
Nice gesture Spud, thats what this forum is all about, helping fellow builders
Ps....isn,t it about time you treated yourself to some new shocks ? (only kidding )
Old 27th January 2011, 10:54 AM
WoW
NO - BUY YOUR OWN.......
Only use Protech - they are the best for the money
Andrew
Old 27th January 2011, 11:46 AM
Andrew
i dont agree i know someone that builds spaceframe cars and has had a load trouble with protech's failing pulling the rod out the end making a right mess!
he had bought loads of sets and didnt get any backup
alot of people b1tch about gaz ones but i find this odd as thay seem to be fitted to tons of kits as std fitment so thay cant be that bad
i would like spax or avo coilovers but you cant get them for good money so im going for gaz
Old 27th January 2011, 11:49 AM
jmh jmh is offline
Hi There,
Someone said to me that the 1.8 CVH sump would fit to the 2 litre zetec .... is this true?
If so I would be very interested in the sump and can send money via bank transfer
Cheers,
Jonathan
nice jesture with the sump btw spud
Old 27th January 2011, 01:34 PM
I've found them great so far Baz, and Kevin at Protech has always been okay. We can only go by our own experiences.... , sump was foc of a car anyway so it may aswell go to a good home.
btw, yes the 1.8cvh does fit the 2l zetec. The zetec bolt pattern doesn't have the 6mm holes at each end and you need to extend the holes in the cvh sump slightly of the sump as the cvh but if you are careful and use some sealer it is okay.
Andrew
Old 27th January 2011, 02:21 PM
fabbyglass
Thing is with these shocks is they nearly all share the same internals......why you ask? Because it goes back to Spax and folk working,learning then leaving and setting up on their own....I know of at least 3 firms
If you want decent shocks that work and last then Spax or Koni.....yep the expensive ones
Old 27th January 2011, 03:24 PM
rpjg1975 rpjg1975 is offline
Pm sent spud
Russ
Old 27th January 2011, 04:37 PM
steve8274 steve8274 is offline
hi
if sump is still available, i will take it.
tried to buy baz r`s (i think) when he swopped his engine but missed out.
thanks
steve
