Old 8th February 2011, 02:52 PM
gtipping gtipping is offline
Default Bolts - Bellhousing to Engine Block
Hi Folks. I need to replace the bolts that attach the bellhousing to the engine block and don't know what spec they are. Engine and box from a J reg 1.8 cvh.
I know some of you have this sort of info in your heads (or give that impression - I would need to look for it) - Being lazy here if you hadn't guessed !!
Old 8th February 2011, 03:45 PM
Here's some info I posted a good while back
I have just had a look on my engine ( I used the original Zetec bolts )
They are M10 X 40mm set bolts ( Fully threaded bolts ) standard metric thread.
One difference over a standard M10 set bolt is that the head size is reduced to take a 13mm spanner .... I believe there is still enough room for a 17mm standard hex head though
If memory serves me right, 6 bolts will do the trick.
They will be the same on the CVH Engine
Old 8th February 2011, 09:20 PM
Thank you.
Old 8th February 2011, 10:15 PM
could always use a cap head (allen key drive)
Old 9th February 2011, 12:32 AM
Cap heads are neat and would want to be rated 8.8
