On the rear upright what angle do i need to rotate the threaded plate for disc brakes?
My Blog: deannoshaynesroadster.wordpress.com (under construction) Being overtaken is a sign of weakness. South Wales Kit Car Club www.southwaleskitcarclub.co.uk WWW.HELPFORHEROES.ORG.UK XBox Gamer tag: D34NNO |
Hang them off the back of the upright
in the book it says dics brakes upright and for drums turn them length ways.
for discs i have seen them at an angle?
think this was somthing to do with cable routing. spikehaus would be the one to ask. i think or brackets where available from 3ge to convert drum type
Have a look at enoch's fine work here http://www.deepfolly.co.uk/2.html
he turned the plate round. I don't believe there is an exact angle to turn it, just turn it round as per his pics to give a little more clearance. Joe. |
Thanks for the help.
Caliper is directly in line with top mount for shocker if made as per book for disc setup. 30 deg ish offset from vertical is some where near but may be better to trial fit before welding
Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice. |
yes look under Handy tips and the pic on part two on enoch's diary it will save you a lot of time and headache later
Regards Axle |
Having one of the threaded holes at 12 o'clock works, I used the top right hole.
| Thread Tools | |
| Display Modes | |
