Old 12th March 2011, 03:46 PM
Default Got my new power train...
Picked up a 1.8CVH and box ( and spare box ) from liverpool this morning.
Are peeps using the normal mounting arms on their CVH?
Will the stock air cleaner clear the bonnet?
Any other known issues with fitting the CVH.
Hopefully have it in and test fired by the end of the month.
Old 12th March 2011, 04:10 PM
think one of the arms hits the steering shaft
dont think the air filter will clear the std bonnet line its massive
Old 12th March 2011, 04:12 PM
Tatey's Avatar
Tatey Tatey is offline
From what I've seen the right hand mounting arm will not clear the steering column as previously mentioned.
I again don't think the air cleaner will have enough space.
If you need any spare bits for your engine then just let me know as I have a dud stripped CVH sitting in my garage.
Old 12th March 2011, 04:42 PM
Got a sump and pickup simon?
Old 12th March 2011, 04:51 PM
Tatey's Avatar
Afraid not, they were given to the person I bought my zetec from.
Old 12th March 2011, 04:55 PM
Last time I worked on a CVH was 2001 .. bloomin heavy beast for what it is.. was a right pain to get out the car.
Old 12th March 2011, 04:56 PM
out the back of the car that is.....
Old 12th March 2011, 05:12 PM
james3004's Avatar
The prototype car had an aftermarket airfilter with a hole cut in the bonnet for it, but then it was a pinto...
Maybe you could still do a similar thing?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 12th March 2011, 06:33 PM
I will just build a ducted feed if it's too close.
Old 12th March 2011, 08:16 PM
John.W John.W is offline
Default Cvh
TT have a look here http://www.tamarisktechnicals.com/pages/roadster.html
this should give you all the answers you need
Regards
John
