Old 30th March 2011, 08:24 PM
tkpm tkpm is offline
Default Measurement Needed
Hi Folks,
Need help from someone who has the nose cone and rear tub fitted, what i need is the overall lenght of the car.
My build is currently 3+ miles from home and i'm going to move it to my garage at home. But i need re-arrange my garage so i can fit the roadster and my day to day work tools in the garage.
Terry
Old 30th March 2011, 08:28 PM
From the tip of the most frontal part of the nose to the rear lower edge( longest length of the car ) of the GRP rear tub is 331cm
Old 30th March 2011, 08:29 PM
Thanks Andy...
Old 30th March 2011, 08:32 PM
and the widest width is 172cm from extreme outer edge of the rear wings
My pleasure
ps....I cheated....the question had been asked before, a long time ago & i had replied to that thread too so the answer was in my post history
Old 30th March 2011, 09:27 PM
CaptainCrash1971's Avatar
HAndy, any idea the height of the engine bay from bottom rail to top of bonnet, need to see if my engine will fit without modification.
Costs so far :- Too much but somehow not quite enough
http://alansroadster.blogspot.com/
Old 30th March 2011, 09:36 PM
hang on a mo, I,ll just check my past posts as I,m sure I,ve covered this some time ago too
Old 30th March 2011, 09:48 PM
You have the height of the chassis from the bottom edge of the lower rails to the top of the upper rails = 355mm,
the top of the bonnet is 230mm above the upper rails at the scuttle end & if my memory doesn,t fail me 171mm above the upper rails at the nose cone
so you have 585mm from base rail to top of bonnet at scuttle end
526mm from the base rail to top of bonnet at the nose cone end .
depends which bonnet you fit, as the new Saturn bonnet gives greater clearance in its larger bonnet bulge.
hope that helps.
Old 30th March 2011, 09:57 PM
Thanks for the measurements Andy
Have 300mm to spare in lengh and about a 1m in width and still have a decent work area, just need to clear out 14 years worth of junk from my old business.
Terry
Old 30th March 2011, 10:03 PM
no probs Terry , glad the info helped
Ahhh I remember the garage clearout
I,m building my car at my mothers home, as a family of 7 we moved in 40 yrs ago.....i,m sure you can imagine how much junk was in there
Its a good sized garage, got my Roadster in & still has about 10ft of work space in front of it. Only junk in there now is MYYYYY junk
Old 30th March 2011, 10:07 PM
cheers Andy
knew I could rely on you. Looks like my temporary engine will fit without any alterations at all.
thanks again
Alan/Bob
