Old 16th May 2011, 10:46 PM
misty misty is offline
Default pictures
Hi all just checking would this be ok for mr iva
hope so
many thanks to all
Old 17th May 2011, 09:26 AM
Just an observation Misty but the 2 following points spring to mind !!??
1: The joiner that has been welded nearest the steering wheel end has possibly ruined the integrity of the collapse-able element of the steering column.
This triangular section of the shaft is designed to kick the steering column & steering wheel to one side in the event of a severe frontal impact.
A collapse-able section to the steering column is a mandatory element of the IVA test & if memory serves me right, must be type approved.
2: You will need some kind of bearing / bush to support the steering column, without this support you are not likely to be able to keep the steering column rigid enough to meet IVA requirements.
The above points are just my own personal understanding of the current IVA regulations.
Old 17th May 2011, 09:31 AM
I think you'll struggle with the collapsible requirement, with this particular design.
Old 17th May 2011, 10:43 AM
nope thats a good and proper fail. no collapsible device and there isnt enough deflection in the haynes design to get away without having built in collapsibility.
you also have no support bearing on the upper part of the column near the uj.
may i ask why did you hack it up like that? you are going to need a new steering column now.
Old 17th May 2011, 05:23 PM
oops back to the drawing board
thanks to all
