Old 25th June 2011, 10:00 PM
Default Spring rates
Is there a rule of thumb or simple way of calculating spring rates if corner weights are known. Or is it just fit the standard adjustable and wind up the adjusters to get ride height. Also i read an older thread about progressive springs, has anymore work been done on the subject?
Old 28th June 2011, 04:22 PM
Default anybody know the answer?
Poundage of springs over corner weight anyone? Please.
Old 28th June 2011, 05:47 PM
tkpm tkpm is offline
I have 350lbs on the front and 250lbs on rear.
Terry
Old 28th June 2011, 09:07 PM
Depends on your weight as to rear spring rate,if they are not high enough you will not get the corner weight right and it makes a big difference to handling.
