Old 31st October 2011, 10:29 PM
Andy_B Andy_B is offline
Default Help with Brake lines (kit spares)
Am looking at these brake lines http://www.kitspares.co.uk/shop/item...=5005&catsub=0 but they seem to have 10mm x 1 male ends on each side ? the only bulkhead fittings i can find are both male ends..i have my brackets welded in position as per the book .. am running discs on the rear so was going to do a short run of copper from the caliper to another bracket i will weld onto the upright then the flexi to the chassis bracket...anybody done this and has some pics i can have a look at ?
Old 1st November 2011, 07:47 AM
Wgroove Wgroove is offline
Hi Andy, i also have the same from Kitspares.
I also welded a bracket on the rear upright, and used a short piece of copper pipe.
I dont have a picture of it, but check out the album of David Murray.
You will find a picture in his gallery 3, i also used his picture as an example.
http://www.haynes.co.uk/forums/member.php?u=1140
Regards,
Wim
