Old 14th November 2011, 01:45 PM
bertie_bas205's Avatar
bertie_bas205 bertie_bas205 is offline
Default Could someone.....
Measure the width (@ the bell housing) and length of a Type-9 and/or an MT75 gear box??
I would also like the width of the main gearbox....
I'm wanting to compare the size to a LT77 gearbox so i know what tunnel i need.....
Bertie.
Cost so far? £1031.32 and i dont have one yet......
Old 14th November 2011, 02:09 PM
Ashtonr Ashtonr is offline
Interesting I'm looking at fitting a lt77 box behind a v8 to my Roadster, I currently have a MT75 box fitted. I will try to measure it for you but need to get it on some ramps first.
Old 14th November 2011, 02:12 PM
Thanks that would be good.....
Bertie.
P.s, give Phil @ Talon a shout if yer gettin rid of yer MT box, he's trying to fit a Rover V8 to an MT....
Old 14th November 2011, 04:29 PM
Width looks like 210 have a look at http://www.super7thheaven.co.uk/imag...-cvg-646-9.jpg
Old 14th November 2011, 04:51 PM
TSM Locost's Avatar
Default Drawings
You have email.
Be Lucky, Mike.
Old 14th November 2011, 04:52 PM
Thanks for that, bell housing and body are identical sizes, bell housing is 10mm wider than the LT77 and the body is 20mm wider than the LT...
The only thing that might be a problem os the gearstick on the LT77 is gonna sit too far forward. theres 160mm between the boxes....
Is yer gearbox fitted with a linkage which would move the gearstick from its origional position??
Maybe time to fab up a linkage of some nature....
Bertie.
Old 14th November 2011, 04:57 PM
Originally Posted by TSM Locost View Post
You have email.
Got it, just what i needed....
Thanks, yer a good bunch on here....!!!!
Bertie.
Old 14th November 2011, 08:09 PM
QUOTE .Thanks for that, bell housing and body are identical sizes, bell housing is 10mm wider than the LT77 and the body is 20mm wider than the LT...
sdi rover version of this box has an extended gearchange.
http://www.locostbuilders.co.uk/gall...%20gearbox.JPG
