Old 23rd November 2011, 02:51 PM
brainbug007's Avatar
Default Exhaust System
I'm starting to look into how I'm going to setup my exhaust system and any advice would be great I'm running a 1.8 cvh on bike carbs with a rs turbo exhaust manifold so far. The kind of thing I'd like to know is what sort of pipe diameter do I want going from the manifold to the silencer (as doesn't this affect flow rate which affects bhp?) and what sort of silencer is a good but reasonably priced? I wasn't planning on going for anything posh like stainless or chrome as I'd need to be able to weld it all together I guess with my mig and my welds won't be that pretty.. I've seen some slip on things though and would these just need clamping instead of welding?
Old 23rd November 2011, 05:56 PM
I used a 2" stainless steel pip from the manifold to the silencer. The silencer is from a 1200 Bandit. This bolt to the pipe with 3 dome head bolts.
Old 24th November 2011, 01:20 AM
Raw do a 5" not badly priced here
http://www.ebay.co.uk/itm/5-inch-Exh...item20bf2a917a
or another here
http://www.ebay.co.uk/itm/Westfield-...37652827092538
Old 24th November 2011, 08:41 AM
Ok well I've picked up a bandit 1200 can with link pipe for £35 delivered which seemed pretty good So it's just the piping from the manifold to the can to sort now. I'd love to go stainless but I doubt I'd be able to weld it with my mig and skills I was thinking of just using mild steel and then covering in vht paint. So what sort of wall thickness should I be using for that?
Old 24th November 2011, 12:31 PM
The only thing to be careful of with bike cans is they are quite loud, maybe worth doing a db test prior to iva to avoid a daft fail if using one
CVHs arent exactly fire breathing monsters though so you should be ok hopefully!
Old 24th November 2011, 12:33 PM
Ya I was thinking of getting the garage down the road from my house todo a pretend mot on the car before iva and make sure they check things like sound & emmisions for me If the sound is still too high I can always add a db killer I guess.
Old 24th November 2011, 01:03 PM
On the 1200 bandit can I have it is marked as 80db, plus a load of Japanese which I don't understand.
When I have had mine running the exhaust is very quiet compared to the induction nosie from the carbs!!
Old 24th November 2011, 01:23 PM
Cool I should be ok then Least with it coming with the linkage pipe I should be able to just cut that down and then run a length of the flexible exhaust pipe from that up to the manifold with a couple of clamps and some paste to seal it up
