Old 27th November 2011, 02:38 PM
rpjg1975 rpjg1975 is offline
Default Seat width
I have found some bucket seats, width at runners is 39cm and overall width is 50cm at the widest point. Would they be worth a try?
Russ
Old 27th November 2011, 03:01 PM
Hi Russ
I have just had a quick measurement of my chassis.
The width between the inside of the side rails & the transmission tunnel is proximately 450mm.
Got shot of a very nice set of Cobra seats due to the width, If only I gave it some better thought.
Probably could have made the transmission tunnel a bit narrower to allow the fitting of a slightly wider seat.
That said, those Two Cobra seats weighed nearly as much as the bare chassis
Old 27th November 2011, 03:08 PM
Cheers Ronnie,
Just wondering if they're worth a punt cos they arent expensive. Presumably there would be a bit of 'squidge' is the base side boulsters or wonder if a could take a little off the side foam to get some space? I take it there would be a bit more space to be had above the bottom chassis rail going to the outer side panel too...
Russ
