Old 16th June 2008, 09:30 PM
Jezzer99 Jezzer99 is offline
Default More donor questions! XR4x4
Another question on donors - what are the differences with a 4x4 donor? What gearboxes did these cars have and are there any issues I should be aware of using one as a donor? Cheers.
Old 16th June 2008, 09:41 PM
tr7v8 tr7v8 is offline
4 x 4 fordies all use MT75 & have front diff in sump. 99% sure any way!
Old 16th June 2008, 09:55 PM
Thanks - is it a standard MT75 or are there some "gubbins" that make it 4x4 ready?
Old 16th June 2008, 10:05 PM
3GE Components's Avatar
It's a special box, the front prop comes out of a casting that's part of the box.
HTH
John
Old 17th June 2008, 11:15 PM
les g les g is offline
yep he,s right
i have read get the 4x4 box take off the the lump that does 4x4 (propshaft end ) mate standard end of mt75 and you have got ultimate desirable ratios and strength its called a hybrid in racing circles
if what i,ve just posted is wrong please amend
les g
Old 20th June 2008, 07:22 PM
snapper snapper is offline
http://community.rhocar.org/index.ph...=article&id=11
Link to Type 9 and MT75 ratios
In my humble opinion the Cosworth T5 has the best ratios but is still lots of dosh so the V6 Type 9 has the next best ratios but needs a 30mm spacer between box and Pinto bell housing because of the longer input shaft
http://community.rhocar.org/index.ph...=article&id=10
Link to V6 box to Pinto or Zetec
Old 5th July 2008, 09:49 PM
Both type 9 and MT75 were used in 4x4 Sierras.
You can't remove the Transfer casing from the MT75, you need a 4pot RWD MT75 and then have a Trans specialist swap over the front casing from the V6 4x4 to the RWD box.
T5 Won;t fit the V6 without a special belhousing.
Type 9 can be converted to RWD by geting hold of the RWD tailcasing and associated parts, but it's a lot of hassle.
