Old 30th January 2012, 08:58 PM
rapidtornado's Avatar
Default What set-up are you using?
I did try and search for this type of thread and apologies if it has already been done before (maybe someone has a link to the thread?) but I have found it really useful to find folk that are using the same set-up as me to see how they overcome different issues in their build - also where about you are located so people can have a look down the list and see if there is anyone near with the same set-up. If you could put your [name-build setup-location]
So I'll kick it off...
Rapidtornado - Haynes R'ster 2.0iDOHC with MT75 - Ross-on-Wye
Old 30th January 2012, 09:19 PM
1.8CVH, Type 9 - Cumbria
Old 30th January 2012, 09:50 PM
Haynes/ Westfield 7 type car with Ford 2.9L V6 Cosworth (BOB Engine) with ITB's and now fitted with Type 9 manual gearbox.
Dalry/ Kilwinning,
North ayrshire,
Scotland.
Old 30th January 2012, 11:36 PM
chassis started out a Locost, morphing toward a Haynes
Cortina crossflow, type 9, Merkur (Sierra) diff., brakes and uprights, Smiths gauges, narrowed Midget rack,
Illinois, USA
Old 31st January 2012, 04:57 AM
holdenchris holdenchris is offline
2ltr dohc, bike carbs, mt75, haynes roadster, nz.
spent so far $400
Old 31st January 2012, 08:03 AM
Sierra based, Left hand driver, 2.0 SOHC, Type 9 Gearbox, rear drums. Sweden
Old 31st January 2012, 12:16 PM
ST170/carbs/megajolt/type9 located Billingham,Teesside
Old 31st January 2012, 12:31 PM
Wgroove Wgroove is offline
Haynes Roadster, 2.0 Zetec / Emerald ECU, MT75, rear drums - Belgium, Antwerp -
Old 31st January 2012, 01:17 PM
Tatey's Avatar
Tatey Tatey is offline
Haynes, 1.8 Zetec Silvertop/ZX6R Carbs/Megajolt/Type 9 - Northumberland
Old 31st January 2012, 07:48 PM
will_08 will_08 is offline
Type 9 and a pinto of some sort ive a 1600 but might hold out for a 2ltr
