Old 23rd August 2012, 01:16 PM
Shorty Shorty is offline
Default zetec engine ecu
I know most people use bike carbs but I would much prefer to keep the standard injection.
Is this possible? Still trying to get my head round this pats thing but if I used engine, ecu, keys, transponder from the same car. Would that work or need aftermarket ecu and loom?
Old 23rd August 2012, 05:38 PM
Yeah I did know there was a mod needed to the inlet, there were companies making them but can't seem to find any.
I can't seem to find anything on the wiring either, which has to be the hardest part.
I'm sure there will be others that have done this whether it be a roadster or any other car.
Let me know how you get on
Old 23rd August 2012, 06:45 PM
There is a guy in Chopwell that can possibly take the pats off.
Old 23rd August 2012, 08:16 PM
I'm running a Zetec 2.0 from a 1993 Mondeo with standard intake and ECU. I'm building a left hand drive roadster. You will have a hard time routing the steering shaft around the manifold (but it is doable), the access to your master cylinder will not be very simple, but otherwise it is not impossible.
Here's a pic of how much space you should expect:
My current problem is that the diameter of the throttle body flange is 70 mm, but the space between the flange and the bonnet is around 60 mm. So it's not very easy to fit the intake bend under the bonnet, and scoops don't normally extend there.
Old 23rd August 2012, 08:34 PM
i'm guessing you were lucky enough to find an ecu without PATS.
I see that is very tight but shows that it is possible.
flyerncle. I didn't know it was possible to remove the PATS system but that would be handy, I was also thinking it would be useful to keep as would count as a security device for SVA.
Old 24th August 2012, 10:58 AM
I would have thought that as long as you have everthing from the original car it should work.
I intend to use a X20XEV out of my old Vectra and kept the ECU, transponder, ignition barrel and keys for this very reason.
Old 24th August 2012, 01:38 PM
martin62 martin62 is offline
You could try Big wasa on here or on Locost fourm he has working in his car
Old 24th August 2012, 03:15 PM
My understanding is that all early Zetecs were without PATS. Definitely Mondeo of the 1993 model year. Having a pre-1995 engine is useful in the sense of exhaust emissions, too. Later ones practically need a catcon to pass the emissions test.
The problem with PATS is that it's not very well documented, but people say that it can be disabled with just a couple of wires.
Old 24th August 2012, 07:38 PM
Terry, He is a wizard with micro electronics and has removed them from VAG ecu's.
Albert,look at Fiat Punto fluid resovoir,you could use the fittings to make a remote resovoir if you extend the pipes.
Old 25th August 2012, 12:05 PM
Big Vern Big Vern is offline
You need to determine whether your donor has pats, some early cars did and some didn't, my '93 RS did. Try to find a car that is non-pats, there are a few people who can de-pats if you've already got the car but you do need to be sure you have pats before de-patsing otherwise you'll ruin the ECU. Likewise don't mess about trying to make it work, if you've missed an item of the pats system (for example the LH headlight is not connected) then it'll lock the ECU and it has to be sent to Ford HQ for a reset.
Personally I would use bike carbs and megajolt as you can unlook more power that way, with the stock system you have the same power as the donor which for the 2.0L is way down on what you can get out of it.
