Old 5th September 2012, 05:44 AM
Default propshaft to gearbox
Almost at the point of fitting the engine etc.I am wondering what sort of gap people have left between the propshaft and the gearbox when the prop is located into the gearbox to allow for any movement.I am thinking along the line of 5-10mm should be plenty?
Any input/advice appreciated
Old 5th September 2012, 06:56 AM
mgglep's Avatar
mgglep mgglep is offline
Mine has about 20 mm of shaft exposed
My Build pics
Old 5th September 2012, 08:18 AM
If you are chopping the old prop let the gearbox seal run in the same place on the sliding section. The seal then wont have to polish another bit of unused prop.
Old 5th September 2012, 11:54 AM
There's a threaded shaft with a nut protruding on the middle of the sierra diff flange, you need 1.5-2.5 cm of free movement in order to be able to straddle that.
