Old 22nd June 2009, 07:06 PM
les g les g is offline
Originally Posted by John View Post
Having read Chris' tome is it worth me buying the above model vehicle.
It appears that this engine may hit the bonnet and the 5 speed box is bigger, meaning modifying the transmission tunnel.
Does anybody have any experience of using this engine with carbs and the mods required on the tunnel?
Any help appreciated.
John
John it might be worth thnking about
as it will have the bigger front discs and discs at the rear
you could sell/swop the mt75 gearbox for a type 9 and you should be all square on the deal just your engine of choice to source as you can use the column and h/brake so its not a bad option
cheers les g
