  #32
Old 9th April 2010, 04:42 PM
geeman's Avatar
geeman geeman is offline
Originally Posted by deezee View Post
I'd have a good look around the pedal box as it sounds like you have some flex somewhere. I'm using a stronger FWD clutch cover plate thats kinda like off / on. The book pedal and pedal box is plenty strong enough when bolted in correctly.
there doesnt seem to be any problems, however the whole clutch problem may just be me wanting a soft clutch.
Anyway, ive finished the handbrake as the screw on nipple came today, and it worked perfectly. I also received my sikaflex today, and glued the left rear arch on. however it seemed kinda messy as a bit of the sealent is visible on the outside, so i think im just gonna rivet the other one on, infact i ended up riveting the left one anyway so the sealant can set.
my build pics
