Old 9th November 2010, 07:28 PM
Andy_B Andy_B is offline
Default D7 and D8 Question
have tacked these in place but they are sticking up 8mm from SB2 i have the 151mm gap from SB1 to BR12 so my angle must be good TR3 and 4 were bloody perfect with the 85 deg angle...is this ok ? was thinking of cutting a slice in D7 and 8 and flattening them to SB1 and welding ....any ideas ??
Old 9th November 2010, 07:52 PM
have you removed the bottom flat at the 40 degree end of D7 & D8, ?
as in the diagram at the top of page 165 "remove material on fabrication"...
this may account for the problem.
hope this helps
Old 9th November 2010, 08:06 PM
AHHHH YA BARSTEWARD.....i hought i had read the book...but i would only have seen that had i cut my own metal !!....many thanks...resisting the urge to go back out and fire up the grinder....
Old 9th November 2010, 08:10 PM
no probs, glad I helped, but then , I was the one that cut your kit, any queries just shout, total back up etc....
I,m a sad geek didn,t need to look in the book for the above info.....as it happens tho, i,d just cut those same bits for another kit
Old 9th November 2010, 08:40 PM
Tell me about it Andy
Spent ages going through the book so as I could give some help ( Remembered a similar problem when I did mine )
Went to post a reply & found you had beaten me too it .... Yes, I did think " I bet he didn't even need to look at the book "
Old 9th November 2010, 08:42 PM
Thanks very much...just back in from garage and will buff the tacks of tomorrow and see what happens ...am hoping it wont throw the rest of the measurements as they were pretty damn good ...
Old 10th November 2010, 01:00 AM
Locky Locky is offline
Thumbs up
I wish all parts suppliers would offer that sort of service, not just for cars, but in my line of work.
Nothing wrong with being a geek, its something you specialise in, and its good to see you take that much of an interst in your job!! i know of alot of people who work 7.30 til 5.00 and not do much in that time.
If it has breasts or wheels it will give you problems.
Planning Stage
Old 10th November 2010, 07:54 AM
Sorry about that Ronnie
As I read the first post on this thread I was actually in the middle of cutting a kit
cheers Locky,
I just really enjoy the chassis aspect of the build, & if I see a chassis build question/thread I try to help, any builder, not just to builders of kits that I cut.
AndyB....hope it solves the problem, let me know how you get on....couldn,t resist the urge to "fire up the grinder" then??
Old 10th November 2010, 08:19 PM
cheers Locky,
Andy...that tip to remove the flat worked a treat ....dead giveaway when i de-tacked it and saw "REMOVE" written on it !!! i am a diddy....have another question ...i have assembled and tacked on the rear frame...i have a spirit level accross RS6 comparing it with the spot on SB6...RS6 is down on one edge about 2mm (bubble touching left line)...how exact does this need to be ?
Thanks again
Old 11th November 2010, 12:47 PM
Thanks again
no worries about the "Remove" instruction, glad it sorted the problem.
Sorry for late reply on this, been mega busy.
If the rear frame is just tacked, if poss try & "tweek" it so that you get it as level as possible, maybe wedge something underneath it resting on the build table to keep it level whilst you weld it, but make sure if doing that it doesn,t throw the other side out.
Personally I would try & get it spot on if you can, are you sure its the frame & not the build table dipping slightly on that side?
