Old 18th March 2011, 06:13 PM
bertie_bas205's Avatar
bertie_bas205 bertie_bas205 is offline
Default Zetec 2ltr
So as i understand it ye need to use the doner engine for the build to keep it on a dated plate...
Now, the question....
I have the chance of a 2ltr Zetec and want to fit it after I have got it IVA'd.
What do i need to fit this to a RWD gearbox??
Bertie.
Old 18th March 2011, 06:34 PM
Andy_B Andy_B is offline
Possibly nothing..not sure about the clutch but the bolt pattern for MT75 and type 9 box bellhousings are the same ...type 9 smaller MT75 in my todays experience is a big heavy mother f@cker !!!
Old 18th March 2011, 06:44 PM
Bertie.
Type 9 gearbox, 1.8 zetec flywheel, mk1 mondeo clutch kit and a ford capri release bearing part no. ct133
This set up is working fine for me
Old 18th March 2011, 06:45 PM
So am i better off looking for a type 9??
I thought with natural progression the MT75 would be a tougher box??
Bertie.
Old 18th March 2011, 06:54 PM
My feet only just fit in the footwell with a type 9 so mt75 was out of the question for me as they take away footwell space
Apparently type 9 are good for up to 200bhp in such a light car anyway
Depends on your donor aswell i suppose, but you are quite right mt75 is meant to be a stronger box but type 9 is good enough unless you are going big power
Old 18th March 2011, 06:59 PM
Type 9 a bit harder to get hold of now..and if you want age related i would imagine it would count as part of a major component from your donor...ie engine...box...prop...diff...brakes...loom...etc etc i understand it all counts...also you need to make your decision before ordering a kit as the tranny tunnel is different from the book for the MT75 box...the tunnel is wider..which ends up with little room about your feet in the pedal box area...its tight...but can be done with lots of sweary words and help from the peeps on here !!
Old 19th March 2011, 09:57 AM
Looks like its the type 9 then.....
Thanks for yer help lads...
Bertie.
